Farmall Tractors Discussion Board
Re: Re: Re: Farmall H Wide Front - Cost Difficulty
Posted by jakee on December 13, 1999 at 12:11:25 from (205.188.193.173):
In Reply to: Re: Re: Farmall H Wide Front - Cost Difficulty posted by Johnny Angel on December 13, 1999 at 10:27:08:
let,s compare . i have a 49 H that i put a swartz wide front on ,400.00 used ,the 3 point was 500.00 ,12v conversion 100.00.also have 574 shifter that works some times,and dosent right now motor that scream,s it,s brains out to make power,would not want to even think about fixing hyd $$$$$$$$$$$$$$$$ or anything else on it.no the old H,s and M,s were a little unhandy but you can count on them running forever.and not costing ton,s of $$$$$$$$$$$$$$$$$$ all the time.a new 50 hp tractor will run aroun 25 thousand to 30.and will it out last a H or M or any old timer i think not.and the H steer,s like dream with the wide front.every time i use the 574 it coplaines dont load me to mutch or dont spin my wheel,s, the M say,s what do you want done end of it
Post A Followup
: Re: Re: Re: Re: Farmall H Wide Front - Cost Difficulty
