Re: 4-H Homework help! NOT IN BOOK!!!!!
Posted by El Toro on May 25, 2005 at 13:36:42 from (205.188.117.138):
In Reply to: 4-H Homework help! NOT IN BOOK!!!!! posted by Farmallkid From Ont, on May 25, 2005 at 12:05:59:
To answer your question as to what rods caps are:
They are the mating half of the connecting rod to secure the rod to the rod journal on the crankshaft. All parts of the engine should torqued so the parts are tightened to the manufacturer's recommended specificaions. Such as rods, mains, rocker arms and head. Even the flywheel and pressure plate on the clutch. Even wheels too.
If you use acrylic enamel or poly urethane is probably over $100.00 per gallon or $25 to 30 per liter plus hardener. An epoxy primer $30 to 40 per liter plus hardener for $65 500cc (pint). They should've given you a little more info. Hal
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
