Re: A
Posted by Joe Kimbriel on May 25, 2005 at 18:22:24 from (136.200.52.33):
In Reply to: A posted by tractor-ernie on May 25, 2005 at 18:11:19:
Lift a battery terminal and stick a small 6 or 12 volt lamp (whatever battery you have) between the battery and the battery terminal. If it lights with the ignition switch off then you have a problem with external battery drain. Batteries can have internal drain also which means replace the battery.
Post a Followup
