Re: Farmall H, stuck clutch
Posted by Bob M on May 27, 2005 at 06:45:52 from (151.190.254.106):
In Reply to: Farmall H, stuck clutch posted by Pat Connors on May 27, 2005 at 06:15:13:
You figured right Pat - rusting over the winter has caused the friction disk to stick to the flywheel/pressure plate. It's a common problem here in cold, damp upstate NY too. If the clutch linkage needs adjustment, do it now to make sure the clutch is releasing fully (about 1" of free play measured at the clutch pedal) Then do like Sloroll says - rock the tractor back and forth with the clutch pedal fully depressed (works best with the transmission in 5th...) If that doesn't work a few other things that have worked for me: 1 - Block the rear tires agains forward movenent. Then with the transmission in 5th and the ignition OFF, stand on the clutch and "bump" the starter a few times. 2 - If you have another tractor, pull your tractor alternately forward and backward a few feet at a time, again with the ignition OFF, the transmission in 5th and the clutch fully depressed. Last resort: 3 - If you have a flat, traffic-free driveway, push start the tractor in 5th gear. (Or use the starter to start it in low, then "float" shift thru the gear to 5th - I'll explain further if necessary...) Then open the throttle wide while standing on the brakes. The clutch should break free. But BE CAREFUL if you use #3! You need plenty of room, no traffic and good brakes to do this safely! Good luck!
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
