Re: 340 hyd oil
Posted by PUTTER on May 28, 2005 at 20:10:35 from (12.180.170.21):
In Reply to: 340 hyd oil posted by Gary Cole on May 28, 2005 at 19:03:46:
Gary, You add HyTran fluid to your system by removing the large plug just to the left of the shifter on the trans top. The oil runs the hydaulics and also lubes the trans and rearend. It holds around 10 gallons. You check it by taking out the bolt that is in a plug under the left floor pan, It's kinda hard to see because its hidden by the clutch peddle. You fill it till it runs out the bolt hole. Don't change the oil without changing the hydraulic filter and cleaning the screen. A service manual is a great investment. Good Luck PUTTER
Post a Followup
