Re: Questions about my 826.
Posted by ny bill on May 29, 2005 at 10:07:33 from (66.24.196.252):
In Reply to: Questions about my 826. posted by Monty Feagley on May 29, 2005 at 08:33:09:
monty, the 826 is a 12 volt neg ground. it uses 2 6 volt batteries in series, although some have been changed to use 1 12 volt battery (requires modifying the battery carrier box).
ether: any unit from 56, 66, 86, or 88 series should work. as far as checking the one you have, you need juice to the push button (from the key, i believe), then push button to one side of unit, and i think the other side of unit should go to ground.
i'm not an expert on painting, so i'll leave that for someone else. as far as starting it, i'd say you have done what i would do. if that isn't enough, i'm sure we'll hear about it from someone else.
Post a Followup
