Re: Proper installation of safety wire on main bea
Posted by El Toro on May 29, 2005 at 15:46:47 from (205.188.117.138):
In Reply to: Proper installation of safety wire on main bearing posted by David in UT on May 29, 2005 at 14:53:25:
You have the right idea. Just twist the wires together and make a nice it nice and snug. You run the wire through one of the bearing caps bolts and have it long enough to reach the other bolt. When you finish the twisting and then run one of the wire ends through the other bolt head
and pull the twisted wires tight and twist the wire again to secure it. 5 or 6 twists should be enough. Then cut off any access wire. We called this lacing. Hal
Post a Followup
