Re: Do I have an H head gasket problem??
Posted by Michael Soldan on May 30, 2005 at 16:33:43 from (66.203.169.248):
In Reply to: Do I have an H head gasket problem?? posted by John in Ct on May 30, 2005 at 15:04:13:
John, it won't be wd40 that you are seeing. Usually a bad head gasket will show up as coolant in the crankcase. I am thinking of two or three possibilities. On the H air breather system there is a tube from the back of the head into the breather casing, a system for crankcase ventilation. Check there as it could be leaking condensed oil on the back or side of the head. Another possibility is the valve cover gasket leaking enough oil down that it gathers on the edge of the head gasket and appears to be coming from the head gasket. And as you mentioned a hot engine will spread oil far and wide from its source. Check out the things I have mentioned first befor deciding on a new head gasket..good luck...Mike in Exeter Ontario
Post a Followup
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
