Re: Will rear weights from 240 fit Farmall A?
Posted by dr.sportster on May 31, 2005 at 14:30:09 from (209.247.222.88):
In Reply to: Re: Will rear weights from 240 fit Farmall A? posted by CNKS on May 31, 2005 at 11:31:57:
I took a dumbell bar welded it to a peice of channel iron and stacked 90 lbs of steel weight lifters weights on that.Just that 90 lbs made a big difference.My A is very front heavy to begin with due to the snow plow on the front end.Traction improved 100 percent and it stopped getting stuck in little mudholes and wood chip piles.I actually have pulled right out of every situation with the added rear weight.This whole thing is bolted to the drawbar and still gives access to the trailer hitch on the drawbar.
Post a Followup
