Re: Farmall B backfire
Posted by captaink on June 01, 2005 at 08:18:16 from (66.115.214.56):
In Reply to: Farmall B backfire posted by Harry37 on May 29, 2005 at 19:33:03:
If your engine runs and the firing order is correct and you have intermittent backfiring, it could be caused by a lean fuel condition. You alluded to the fact that you had blown back into the gas tank and this had helped but now you have dirt in the bottom of the sediment bowl and it is worse. I would check to make sure that you have good fuel flow to the carburetor for a sustained period (at least a minute) to eliminate this a potential problem.
Post a Followup
