Re: HOW DO I START THIS TRACTOR ?
Posted by Kevin Bismark on June 01, 2005 at 17:45:56 from (152.163.101.13):
In Reply to: HOW DO I START THIS TRACTOR ? posted by Rick in Vermont on June 01, 2005 at 17:35:43:
Do you have spark, do you have a mag, or battery ignition, after you are sure it's out of gear, is there a little round button below the stearing wheel to pull out before you try cranking it...
Post a Followup
