Has anyone ever seen this?
Posted by chadd on June 02, 2005 at 09:55:51 from (63.26.186.103):
I changed the hydraulic oil filter on our 806 this morning. I was surprised to find this crack after removing the plate by the filter. Does anyone know what would cause this or whether or not it would cause a noisy/weak MCV pump? if you put your finger in the tube you can wiggle it. The picture below shows the crack(its in the lower tube)
third party image
Post a Followup
