Re: Has anyone ever seen this?
Posted by SGT K on June 03, 2005 at 00:27:26 from (216.125.213.242):
In Reply to: Has anyone ever seen this? posted by chadd on June 02, 2005 at 09:55:51:
Chadd,
I'm not seeing the crack. Is it in the casting?
I don't claim to be an expert, but the tube you can wiggle is your oil pick-up for the pump, and it should have an o-ring around it. I wish I knew if the oil level was above, or over, this area (I think it is). If the oil level is above the pick up tube a poor seal would just allow some oil to be sucked out of the case instead of through the filter, which shouldn't have any affect on the pump's operation. Surely one of the guys here will know and help us out. Good luck.
Paul
Post a Followup
