Re: M wont start
Posted by El Toro on June 03, 2005 at 10:53:28 from (205.188.117.138):
In Reply to: M wont start posted by bigMman on June 02, 2005 at 20:25:58:
You should put that teaspoon of gas into each cylinder and see if it tries to start. Was that distributor ever removed lately? Hal
PS: Make sure all your plug wires are hooked up
from the cap to the plugs. 1-3-4-2 as you look
at the distributor cap CW. Your compression could be low too from worn rings, sleeves or valves not seating. This is where you obtain
your intake manifold vacuum to pull that atomized
fuel into the combustion chamber.
Post a Followup
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
