Re: Rebuilt A starts and dies immediately
Posted by Wayne Swenson on June 04, 2005 at 11:51:52 from (66.191.70.4):
In Reply to: Rebuilt A starts and dies immediately posted by Georgia Boy on June 04, 2005 at 06:57:19:
Use a tester to determine if there is voltage at the coil input when you turn on the switch. If not, temporarily run a jumper wire from the hot post on the battery or starter to the primary input side of the coil. (small terminal opposite the one attached to the points)
If the engine now continues to run, you have a wiring problem with the switch. Have you converted to 12 volt?
Post a Followup
