Re: 1948 C Restoration
Posted by Pharmall on June 04, 2005 at 19:41:38 from (68.9.106.167):
In Reply to: Re: 1948 C Restoration posted by El Toro on June 04, 2005 at 12:53:58:
Made two discs from 1/2" plate with holes in the center for a 5/
8" threaded rod. The bottom plate is 1/8" bigger than the
sleeve skirt, and the top plate is big enough to put some 1"
standoffs under the edges so that the top flange of the sleeve is
clear to move. Run the threaded rod thru with a nut on each
end. If that doesn't get them out, well, I'm just not sure what
could be keeping them in. If those are the 3 5/16" OD sleeves,
with a 3 1/8" piston, then the sleeve walls are only 3/32" thick...
Post a Followup
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
