Re: 1948 C Restoration
Posted by El Toro on June 04, 2005 at 12:53:58 from (64.12.117.13):
In Reply to: Re: 1948 C Restoration posted by El Toro on June 04, 2005 at 08:38:24:
I restored an A that had the C123 engine and the engine was seized. I poured transmission fluid
over the pistons and I let them soak for a few days and I then drove the pistons out with a piece
of wood. Some of the sleeves came out with the pistons. Two other pistons came out ok and I then drove the sleeves out. They're not pressed in and are held by that old hardened seal at the bottom of the block. You may need a puller that's pretty thick and would grip the outer edge
of the old sleeve if they're that tight. Hal
Post a Followup
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
