88 series turn signals
Posted by K.B.-826 on June 05, 2005 at 20:41:02 from (66.188.212.244):
Got issues with the left turn signal on a 3088. Both flashers work with the light switch in the first and second positions as they should. With the signal light switch in the right turn position, the right flasher flashes and the left flasher comes on solid as they should. In the left turn position, the right flasher comes on solid, but the left flasher does nothing. This all started after the NH dealer failed to correctly match the wiring in the 7-pin lighting connecter on the new chopper to the tractor. Does anyone know if there are seperate flasher units under the dash for the turn signal positions and the warning light position, or am I looking at a turn signal switch problem here? All of the fuses are good.
Post a Followup
