farmall 100 throttle problem.
Posted by u utt on June 06, 2005 at 02:32:57 from (151.205.37.100):
I have a farmall 100 that has developed a throttle problem. The throttle has a mind of its own. When you set the throttle to low idle it will go full throttle all by itself. Also, when you are trying to put the juice to it and put it to full throttle it will just go to idle. Problem is sometimes random and sometimes made worst going up and down hills. Quickly moving the throttle lever back and forth sometimes helps but not for long. The governor looks like it is moving the levers properly. Do not know for sure. Any info or help appreciated.
Post a Followup
