Re: 350D tach cable
Posted by Seeing Red on June 06, 2005 at 17:46:05 from (216.157.202.140):
In Reply to: Re: 350D tach cable posted by Cotton Picker on June 06, 2005 at 11:35:08:
Check to see if the shaft in the rear of the generator is threaded on the inside. If it is, then all you need is the tach drive housing and gears. Not an easy item to find, but not extinct either.
Post a Followup
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
