IH W6 starter and battery advice
Posted by Ron in Mich on June 06, 2005 at 19:02:48 from (66.79.195.86):
My brother and I are working on our 1948 McCormick W6 with 6 volt system. The original starter has 3 mounting bolts and we're not having much luck finding a used 3 bolt type. We may have ours rebuilt if we can't locate a good used one. Do any of you guys happen to know if a starter from the 300 or 450 or some other Farmall will work on the W6? The W6 has the same engine as the Farmall M but all the M starters seem to be 2 bolt style. Also any opinions pro or con about using the 8 volt battery on this tractor instead of the standard 6 volt. Thanks in advance for your help and opinions.
Post a Followup
