Re: IH W6 starter and battery advice
Posted by Bob M on June 06, 2005 at 19:48:02 from (66.67.18.211):
In Reply to: IH W6 starter and battery advice posted by Ron in Mich on June 06, 2005 at 19:02:48:
Ron - My advice is to get your existing starter rebuilt rather than trying to find a used one. This way you KNOW you have a good starter and that it fits!
I regard 8 volt batteries as a "band aid" fix for hard starting problems. They are more expensive - when you can find them at all. And they are tough to keep properly charged, especially if you don't use the tractor much or run it at low speeds.
Better approach is to spend the $$ getting the starter in good working order. Also make sure you have properly sized battery cables with GOOD (soldered) terminals, and a good 6 volt battery. You'll then have no need for an 8 volt battery!
Post a Followup
