Re: H tranny question
Posted by jeff_MI on June 06, 2005 at 20:15:27 from (66.227.189.255):
In Reply to: H tranny question posted by Wayne7 on June 06, 2005 at 19:00:47:
There's an access hole that allows you to get to the transmission-engine shaft coupling and the transmission-hydraulic pump coupling. If you remove the transmission-hydraulic coupling, there will be a slotted "nut" that is connected to the front of the countershaft - this is what needs to be removed. I may not have the best way of doing it, but I put the tractor in low gear, put a crowbar in the slot, and give a twist. I'm sure there's a tool for this, but I try to live life to the fullest and make do with what I have (tongue in cheek).
Post a Followup
