Re: also,,,,
Posted by ChadS on June 08, 2005 at 15:45:05 from (66.228.96.225):
In Reply to: Re: also,,,, posted by DWV on June 08, 2005 at 09:19:20:
The H housing does work, long as I used the shim behind the bearing. I used brass, so it can have something that gives just a little for breaking it in. The shim fits tightly inside the H bearing housing, and moves the bearing forward about .210. The pinion shaft, no matter what, rides in this location, The pilot, or thrust bearing up front is still deep inside the constant mesh gear, and when installed, does not feel any different than when the H pinion was in it. The snap clip will keep it from moving forwards, and the brass shim will keep it from moving back. Hopefully,,,,,,,,,, LOL. The reason I did this swap is to take the tractor out of 4th gear while pulling, back to 3rd. A bit heavier looking gear set, and still be as fast as 4th. Always thought that this tractor was between gears in 3rd, and 4th, could handle alot more in 3rd. 4th gear,, well,, it will run, but still not working the engine the way I am hoping this will do by this swap. My old 4th, teeth was worn so sharp, it would kick out of gear, cause it was so tapered on one side of the gear. I did manage to find the perfect, "used" gear set to put in, just a little wear on 2nd and 3rd, but nothing to worry about, 4th was perfect. So, Im a step closer to getting it back together. I found, I like doing transmission work in the letter series Farmall's. Once they come apart, makes it alot easier to put back together! On the earlier post,, I just used the W4 pinion, and ring gear, used the H bearing cages,, when I got the gear set, I could have got them, but, I told him to keep what was left, Ill make it work...?? LOL! Thanks! Thought there was something different,,,,,, Chad
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
