Re: Farmall H steering wheel removal
Posted by Jeff In Ontario on June 08, 2005 at 19:12:22 from (24.112.85.18):
In Reply to: Farmall H steering wheel removal posted by narrowfarm on June 08, 2005 at 18:35:20:
Narrowfarm:
I had to change the wheel on my H about a year ago, and after removing the nut, we couldn"t get the thing to budge. We ended up using a puller on the back of it to pry it apart (also used a ton of WD40). Finally got it off, and putting the new one on is a piece of cake.
Good Luck!
Jeff
Post a Followup
