Re: 460 Diesel Won't Start: Busted Injector Pump S
Posted by Brian in Ne on June 10, 2005 at 17:33:10 from (12.37.227.90):
In Reply to: 460 Diesel Won't Start: Busted Injector Pump Shaft posted by Ron Smith on June 09, 2005 at 19:42:19:
Guys you are right by having him take the pump to a shop. Whenever a driveshaft in a Roosa/Stanadyne pump breaks 99% of the time it's seized. Your shop should be able to tell you what caused the seizure by the marks on the rotor. Make sure they have pressed it apart to show you. Stanadyne had a bulletin on pump seizure patterns and it helps to diagnose the root cause of the seizure.
Post a Followup
