Re: Serial #s - Super M
Posted by farmallhal on June 12, 2005 at 09:36:33 from (64.24.35.16):
In Reply to: Re: Serial #s - Super M posted by MrIH on June 12, 2005 at 07:11:07:
As Nat stated it was converted somewhere along the line after it left the factory. Those suffix codes are affixed by the factory based on it's "as built" configuration. Probably a simple conversion from LPG to gasoline but I don't know all the differences. Seems like I've seen on the forum that LPG cylinder heads are highly sought after by the pulling folks as they have higher compression. You might check the part no. on the head to see if it was changed to gasoline when it was converted. If the LPG head is still on the tractor you probably have some extra horses.
Post a Followup
