Super A Trouble/ Other Questions! Input Needed
Posted by Mark (PA) on June 12, 2005 at 18:01:29 from (24.50.158.215):
Hello All
I have a few questions problems and I'll start with the most pressing.
Today I was brushhogginng (or started anyway) a 10 acre field. Things were going Ok but the tractor does not seem to be running as strong as It should. can anyone tell how to check if it is running on all cylinders. It just seemed to REALLY dog out alot and it wasn't missing noticeably but maybe I just don't know what to listen for. so any help on this front (what to check? and how!) would be great.
Of note here. After the 2nd problem happend (read below) I Was traveling thru the field back to the barn and some whisps of white smoke started coming out of the stack. This took place for about 1 minute total. not HEAVEY white smoke but noticeable. I was really worried something with the engine was terribly wrong (from above you can tell I don't think its running right anyway)
Is this a sign of anything I need to worry about... it was a HOT day here for PA. about 85.
2nd problem... I got about 10 trips around done and a bolt on the brush hog sheered off. it was the bolt that connects the U joints to the spindle that turns the gearbox that in turn, turns the blade... does that make sense? It is and OLD unit. VERY old. No markings... I am wondering if this should be a softer bolt that it made to shear? or just a regular one?
3rd question. I have two smaller tractors. on 782D cub cadet and 1 982 cub cadet both in excellent shape and I love using them to mow grass and I also have a brush hog for hte 982. BUT I have just recently moved and I'm wondering if a sub compact or compact might do me better. Trade those two in possible on a new one that I can do multiple tasks with.
I need a front end loader, grass cutter, and brush hog tractor all rolled into one.
Does anyone have a good suggestion on a model to look at for this task? I know this is IH but I saw the other day kubota has 0% financing right now. not sure if CaseIH does or not.
THanks for ALL your input and help guys. Really appreciate it.
Post a Followup
