Re: Super A Trouble/ Other Questions! Input Neede
Posted by MagMan on June 12, 2005 at 18:09:37 from (64.12.117.13):
In Reply to: Super A Trouble/ Other Questions! Input Needed posted by Mark (PA) on June 12, 2005 at 18:01:29:
Well it sounds like maybe a blown head gasket. I guess I would check the rad for bubbles while its running first.Then see if there is any antifreeze in the oil by slowly loosing the oil drain plug.
As far as the shear bolt goes thats what there made for I would go to tractor supply and get the sofest bolt They have. Look for the lower # of dashes on the top of bolt or none at all. probly 5/16 or somthing and replace it and get a few more for the next time it happens.
JON
Post a Followup
