Re: Replacing knuckle in PTO
Posted by Allan in NE on June 13, 2005 at 05:30:51 from (148.78.243.24):
In Reply to: Replacing knuckle in PTO posted by Working on June 13, 2005 at 05:15:21:
Hi Work,
Not familiar with your particular outfit, but it may be configured like GM's u-joints. From the factory, they are held in place by an internal ring of teflon.
What you do is, SLOWLY heat the cup area of the yoke with a torch and the stuff will boil out of a little bleed hole. When the teflon stops "worming" out of the bleed hole, you can then remove the cup in the usual way.
Clean the yoke up good; replacement cross cups are then held in place by the conventional internal C-clip.
DON'T HEAT THE YOKE TOO FAST! The darn things explode and shoot that cup across the shop like a bullet.
Allan
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
