Re: Replacing knuckle in PTO
Posted by captaink on June 13, 2005 at 11:21:04 from (66.115.214.56):
In Reply to: Re: Replacing knuckle in PTO posted by Working on June 13, 2005 at 10:55:07:
You are right, they are not the easiest to get apart. I squeeze the yoke in a vise using a ½” drive socket that is smaller in diameter than the bearing against one side in an attempt to push it over far enough to get the clip out. Usually I had the best luck by driving the clip off with a hammer and a punch until I could get something under the opposite side to pry it off with. After that it’s pretty much like any other universal joint.
Holler if you need more info.
Post a Followup
