Re: Farmall M runs and dies
Posted by RustyFarmall on June 13, 2005 at 15:37:58 from (199.120.81.220):
In Reply to: Re: Farmall M runs and dies posted by nositri on June 13, 2005 at 15:09:13:
A new needle and seat is not enough, you need to completely disassemble the carb and soak it in carb cleaner overnight. In other words, completely overhaul the carb. Would also be a good idea to inspect the gas tank on the inside, it might be full of rust and other crud. While you're at it, remove the sediment bowl assembly and clean it good. If you don't like what you see in the sediment bowl, replace it. A new assembly is under $30.
Post a Followup
