Re: 350 questions
Posted by Nat on June 16, 2005 at 07:56:55 from (64.80.110.44):
In Reply to: Re: 350 questions posted by SHeiserman on June 16, 2005 at 03:26:26:
Doubtful.
If it was a broken key, the tractor would not run because the distributor is driven off the hydraulic pump. The pump wouldn't get hot, either.
If it was air in the system, the pump would not get hot.
The system is plugged up somewhere along the line. That's why the pump gets hot. It's dead-headed, and just keeps thrashing on the same oil.
Just moving the levers and centering them doesn't mean a valve isn't stuck. The linkage could be broken. All three valves should center with a little snap to them. If one just slides or flops around... That's your problem.
There's a filter screen on the side of the hydraulic "tower" (hydra-touch unit) there under the dashboard. It's right out in the open on one side or the other. Drain the hydraulic fluid and pull that screen. Betcha its plugged with all kinds of cruft.
Post a Followup
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
