Re: taking off in 5th gear on m
Posted by captaink on June 17, 2005 at 11:16:46 from (66.115.214.56):
In Reply to: taking off in 5th gear on m posted by nositri on June 17, 2005 at 10:47:29:
As others said, get it rolling in 4th then wind it up and “double clutch” and shift to 5th while rolling. If you can get your M rolling by staring in 5th without having what you describe as happening, let us know how you do it without smoking the clutch.
In case you haven’t heard the term “double clutch” before here is how you do it. When you get rolling good speed in 4th, step on the clutch, pull the shifter into neutral and idle the engine down and let the clutch out at the same time. This will slow the input shaft speed to closer to the pinion shaft seed. When the engine speed is close to idle, step on the clutch again (the double) and shift into 5th. With practice this procedure will greatly reduce if not totally eliminate the “clash” or grinding when you shift from 4th to 5th.
Post a Followup
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
