Re: Correct driving and Shifting on my H?
Posted by Bob M on June 20, 2005 at 10:02:39 from (151.190.254.108):
In Reply to: Correct driving and Shifting on my H? posted by Tanner Clark on June 20, 2005 at 07:20:16:
As Allen points out below these transmissions are were never intended to be shifted while underway. Rather you pick whatever gear you need for the task before starting in motion. However getting underway in road gear is problematic – especially if you are pulling a wagon or other heavy rolling load. For this it’s MUCH easier on the clutch to get the tractor started in 4th gear, then once under way shift up to 5th. ---- Shifting 4th to 5th takes a bit of practice, but once mastered is easily executed without clashing. Here’s how: Being pick the appropriate spot. You must be on a hard surface - never on soft ground. And you must be either level or heading downhill. (Reason: You gotta able to coast 30 - 40 feet without losing much momentum while executing the following steps…) First get the tractor rolling as fast as it will go in 4th gear. Once underway simultaneously depress the clutch and return the gas lever to idle. As the engine RPM’s fall off, move the gear lever to neutral. The instant the engine RPMs reaches idle, quickly release then depress and hold the clutch pedal (gear lever still in neutral…) Now move the gear lever to 5th. If you’ve done it right you’ll still be rolling and the lever will drop right into it’s notch without a hint of gear clash. Finally release the clutch, reopen the throttle and enjoy the ride. --- Key is to practice a few times – it’s not hard to master. But once you think you’re good at doing a flying road gear shift on an H, try executing a “flying shift into road gear” on a hand-clutched tractor! (It takes an operator with at least 3 arms to execute this one gracefully!)
Home
| Forums
Today's Featured Article -
A Towny Goes Plowing - by Anthony West (UK). I live in an area renowned for its rural beauty. Small fields with hedgerows and trees are common place, as are small hamlets with village greens and the odd duck pond complete with swans. The center of any village once the shop is closed is the old tavern. Rustic places with cheerful names like "The Griffin" "Red Lion" or "The Plough and Harrow" are found dotted around the country lanes all over the place. The warm glow of yellowish light can be seen for quite some distance at dusk, and
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
