Farmall Tractors Discussion Board
Re: Farmall M vs. Super M (specs)
Posted by john d on December 15, 1999 at 12:23:38 from (206.141.74.34):
In Reply to: Farmall M vs. Super M (specs) posted by OL' JR on December 14, 1999 at 19:55:00:
Ratios are faster in some gears on the SM. SM also usually had slightly larger tires on the rear.
Post A Followup
: Re: Re: Farmall M vs. Super M (specs)
