Re: Spun bearing
Posted by El Toro on June 22, 2005 at 05:06:59 from (205.188.117.73):
In Reply to: Spun bearing posted by Johann on June 22, 2005 at 04:55:50:
What is the condition of the rod journal on the crankshaft? To pull the crankshaft would require
pulling the engine since your clutch disc, pressure plate and flywheel are attached to the crankshaft. If the rod journal surface is rough
from the spun bearing, probably will require the crankshaft to be ground undersize. Hal
Post a Followup
