Re: 43 H Need a Head Start
Posted by Theman on June 23, 2005 at 09:11:47 from (65.248.77.5):
In Reply to: 43 H Need a Head Start posted by ChrisL on June 23, 2005 at 08:35:52:
Chris, the six-volt system on your H didn't require a ballast resistor. It would have only been needed when a previous owner dropped a 12-volt battery in it. In fact, it was probably originally equipped with a magneto. You can determine whether a ballast resistor is present either by visually tracing the coil primary hot wire back to the switch, or measuring voltage to your coil. A reading greater than 9.5 volts would indicate there is no ballast resistor present.
Running a 6-volt coil with 12 volts will burn the points and eventually cause the coil to fail. There are 3 ohm coils available which don't need the resistor to run on 12 volts. You should check to make sure which one is on your tractor.
#1 cylinder is indeed most forward.
With the #1 cylinder at compression TDC, the spark will occur when the points just open.
Post a Followup
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
