H engine vibration
Posted by JBW on June 26, 2005 at 07:15:50 from (24.241.16.173):
My 43 H was overhauled with new valves, sleeves, pistons, rings, bearings, ground crank, resurfaced flywheel and new clutch. It runs much better, except it has a vibration (as it did before the rebuild) at around 1/3 throttle. It smoothes out at higher speeds, but at 1/3, it vibrates everything. Could the flywheel have somehow warped over the years and gotten out of balance ? Is this common ? I’m sure its coming from the engine as I’ve taken off the water pump belt and the vibration is still there when the clutch is pushed in. Thanks for any help.
Post a Followup
