Re: 4 postion lite switch 6 volt gen. with cut out
Posted by Haas on June 27, 2005 at 18:31:57 from (12.65.24.68):
In Reply to: 4 postion lite switch 6 volt gen. with cut out and posted by lekander883 on June 27, 2005 at 17:34:13:
The 4 position switch does the same function whether it's a mag or battery ignition. The four positions are high and low charge, and high and low (dim and dimmer) lights. High and low charge simply grounds the generator field coil for high charge and puts a resistor in the circuit for low charge. High and low lights puts full voltage to the lights on high and a resistor in the light circuit for low lights. When the lights are on the generator is on high charge. If you still have a cutout relay, I suggest you replace it with a voltage regulator. You will have a lot less battery problems. You can get a voltage regulator that mounts on the generator just like the cutout. If you change to the regulator, the high/low charge switch for the generator will have no function, but you can leave it there, just not connected. No one will know the difference except you.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
