Re: SA rear axel seals replacement crank pully
Posted by scott#2 on June 28, 2005 at 08:36:20 from (138.88.115.86):
In Reply to: SA rear axel seals replacement crank pully posted by scott#2 on June 28, 2005 at 06:54:13:
Thanks guys,
Still a little in the dark on the pully. Is it bolted on? I didnt see a bolt in there. If it isnt, what keeps it from coming off? Oh, I guess its not on a taper shaft, best to heat it up in a oil bath to get it back on???
Post a Followup
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
