Re: SA rear axel seals replacement crank pully
Posted by El Toro on June 28, 2005 at 11:34:49 from (152.163.101.13):
In Reply to: Re: SA rear axel seals replacement crank pully posted by scott#2 on June 28, 2005 at 08:36:20:
You can heat it in your oven, its not so messy as an oil bath.
Cub uses a bolt, look carefully for a bolt on that damper pulley. They're tight on a Cub, a press fit. Hal
Post a Followup
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
