Re: Farmall M
Posted by Lee Wv on June 29, 2005 at 20:04:11 from (205.188.117.73):
In Reply to: Farmall M posted by Nositri on June 29, 2005 at 11:57:21:
I would also suspect the "new"starter first.It sounds like the drive gear is bad.It is supposed to grip 1 way and slip the other!If the wrong gear is installed it will not grip!It sounds like the gear on yours is for a starter that installs from front to back!Also,I don't know about the flywheel but the clutch comes out the bottom without splitting the tractor,I suspect the flywheel will come out the same way.
Post a Followup
