Re: Farmall M
Posted by captaink on June 30, 2005 at 06:26:23 from (66.115.214.56):
In Reply to: Re: Farmall M posted by scruffyia on June 29, 2005 at 13:32:22:
Just an FYI- A, B, C, H, & M starters from the factory were "spin in" drives, however later tractors (like 460 & 560) did use a solenoid to pull the drive into the flywheel first. I’m not sure where the switch came though.
Post a Followup
