Re: 12 volt coil?
Posted by Janicholson on June 30, 2005 at 10:12:55 from (199.17.6.77):
In Reply to: 12 volt coil? posted by Nebraska Cowman on June 30, 2005 at 07:17:18:
From the shape I'd say it is IH for sure (you probably know that). It is black and shows no red so I'd also say it is not off of a letter series, nor a early number series. Check with the parts department to see if there were resistors on later model tractors. Some equipment, Ford cars for instance, use a resistor wire that goes from the switch to the coil. And a bypass wire from the solenoid to give the coil full volts with the starter in the circuit. If the coil has the same Ohms of resistance as a six volt coil (or within an ohm of it) it is a 12 v with resistor required. If the resistance is almost twice the Ohms of a six volt, it is probably a "non-resistor" type. I gave no Ohm specs because ohm meters don"t always talk alike at low ohms unless they are too expensive. Good luck, Jim Nicholson
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
