Re: what head work is needed when ringing M???
Posted by 26Red on June 30, 2005 at 11:45:11 from (170.92.100.2):
In Reply to: what head work is needed when ringing M??? posted by scruffyia on June 30, 2005 at 09:04:44:
Maybe a compression test on the cylinders would give you a better perspective on what needs to be really done? Alot of these tractors will burn a little oil and run fine for chore work. But if you're annoyed with the oil burning, go all out and have the head overhauled. Grind the seats, lap the valves and put in new valve stem seals...
Post a Followup
