1466
Posted by Chris Brown on June 30, 2005 at 19:53:44 from (64.91.17.31):
My neighbor/friend has a 1466 thats sort of for sale,at least for sale to me. Now the description: Needs 4 tires,all worn out.Needs tie rod ends.Starts and runs good. Shows 9000 hrs. Oil pressure ok when hot. No bad gear noises.Does jump out of high gear going down hill.TA seems ok,but did"nt pull it hard.It has a radiator leak that I can probably fix myself. AC needs charged,blows cold for a few days and leaks out. You can tell by looking at it,it has done alot of hard work in it"s lifetime,but it is still a solid old tractor. I plan to farm my 80 acres of beans and hay with it,pretty light work for a 1466. Is it worth $4500 ?????
  • Re: 1466 Sleepless in Ohio 15:35:20 07/01/05 (1)
    • Re: 1466 Van in AR 08:55:14 07/03/05 (0)
  • Re: 1466 MAGNUM 08:03:46 07/01/05 (1)
    • Re: 1466 dhermesc 09:30:40 07/01/05 (0)
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
