super A running issue
Posted by Phil W in Michigan on July 01, 2005 at 20:24:36 from (24.236.133.40):
I am trying to get this new super A running better. It starts and runs but it doesn"t seem to run well at higher RPM"s. The engine starts bogging down and then seeks. Some times it just starts bogging down and stops. It seems to run smoother at lower RPM"s. So far I have changed out the old fuel; shortened the adjusting rod between the governor and the carburetor(I think that is what it is) and I fixed the lever on the throttle so it will hold its postion on the throttle quadrant. I also put in a new battery. Does anyone have any other suggestions or know what type of problem this might be?
Thanks,
Phil
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
