Re: 43 H Lift All w/Trip Bucket
Posted by ShepherdBill on July 03, 2005 at 06:53:04 from (152.163.101.13):
In Reply to: 43 H Lift All w/Trip Bucket posted by ChrisL on July 03, 2005 at 05:14:24:
If you have an IHC loader like the model 30, it stores oil in the front of the cylinders. There is a pipe connected to the top of the torque tube or whatever it is called - to the right of the battery with a hose from each cylinder attached the is the return for the oil stored in the cylinders. The hoses from each side of the tractor are from the lift-all pump. If your loader has this, you can add oil to the cylinders thru the plug on the top upper end of the cylinder. If your loader is something like this & you don't get it figured out, I can e-mail you a drawing.
Post a Followup
