Re: SC clutch problems - Long Post
Posted by JB2 on July 03, 2005 at 19:09:43 from (69.196.154.214):
In Reply to: SC clutch problems - Long Post posted by skycarp on July 03, 2005 at 18:51:55:
Hi Skycarp, on the SC that we owned, when the gears started to grind it was time to replace the pilot bushing in the flywheel. The problem is this is only a bronze bushing and when the clutch grit gets into it, it prevents the transmission drive shaft from turning in the pilot bushing when the clutch is depressed. The transmission drive shaft should stop turning and spin in the pilot bearing when the clutch is depressed.
Hopefully by fixing the clutch adjusting mechanism it will fix the grinding gears but if it dosen't then probably a sieze pilot bushing.
To fix requires splitting the tractor.
Good luck
JB2
Post a Followup
